Hello Everyone,
I have been working on converting my 6x10 Trailer as our new hunting lodge when we head out on our weekend hunting trips. My major question is dealing with the electrical. I have seen multiple posts on here and I plan on implementing a few ideas to keep the costs down.
Currently I use the 20 Amp Marinco plug and the built in GFCI power strip. It’s a lot like this one: http://tnttt.com/viewtopic.php?f=30&t=37732
The next beast is the DC power. I have a mounted battery box on the front of the trailer with a very large Deep cycle battery. I have 8 Gauge wire ran into my trailer and that’s where I stopped. I have a Blue Seas fuse panel, but need to add a fuse or a master cutoff switch. I guess my major question is how big of a fuse do I need?
I will have a 750 watt inverter in the mix as well. I was going to have 2x LED porch lights on each side of the trailer, 1 to 2 flood lights on the back of the trailer in the event we need to some cleaning and a few puck lights internally for lighting. The converter will be running my CPAP when I am sleeping and to charge are phones. I was thinking I could get away with adding a 30 Amp inline fuse off the battery box. Internally to the trailer add the master cutoff switch and then feed it back to the fuse panel. I plan on changing out the 4 pin connector to a 7 pin connector so I can have my new truck charge the battery as we are driving down the road.
The only things that could be added down the road is a TV and extra lights, but that is about it.
Thanks for your time to help me out.
