Rear view camera on the tear.
Re: Rear view camera on the tear.
Postby Shadow Catcher » Wed Jun 29, 2016 6:00 pm
We now have results, it worked. Our first camping trip was over the last two days and the camera works well. It is wired to the marker lights so turning on the lights feeds the camera. I do not have a picture of the monitor in the car, it is mounted upside down because the camera is mounted upside down.
143018143019
Images: 192
Postby m.colley » Fri Jul 01, 2016 11:32 am
looks good SC, might be worth looking into for my CTC.
Martin
m.colley
Images: 83
Postby Shadow Catcher » Fri Jul 01, 2016 4:23 pm
Martin, I was concerned that since this camera monitor is bluetooth/wireless that there might be too much distance, or interference so tried both prior to making irreversible changes, cutting wires etc. There was however a bit of OK is this going to work when we started out. One aspect that I like is that you absolutely know you have clearance before merging. It is an exceedingly wide angle lens and I do not know if that can be compensated for in the monitor yet or not.
Images: 192
Postby lrrowe » Fri Jul 01, 2016 7:13 pm
Shadow Catcher wrote:We now have results, it worked. Our first camping trip was over the last two days and the camera works well. It is wired to the marker lights so turning on the lights feeds the camera. I do not have a picture of the monitor in the car, it is mounted upside down because the camera is mounted upside down.
143018143019
Good job! :thumbsup:
Bob
lrrowe
Images: 439
Postby capnTelescope » Fri Jul 01, 2016 10:18 pm
lrrowe wrote:Good job! :thumbsup:
+1 :thumbsup:
Brad
My Build
capnTelescope
Images: 364
Postby m.colley » Sat Jul 02, 2016 5:12 am
Shadow Catcher wrote:Martin, I was concerned that since this camera monitor is bluetooth/wireless that there might be too much distance, or interference so tried both prior to making irreversible changes, cutting wires etc. There was however a bit of OK is this going to work when we started out. One aspect that I like is that you absolutely know you have clearance before merging. It is an exceedingly wide angle lens and I do not know if that can be compensated for in the monitor yet or not.
I can understand about the distance issue, that would be my concern as well especially since my CTC is 18' not including tongue, then add in the length of my truck. I've wanted a back-up camera for quite a while, and being able to run two cameras on this would be perfect, one for backing/ hitch hook ups and one for watching the butt end and sides of trailer. Its a reasonable price too so that makes it even better. I got into the habit several years back of running with lights on anytime I have a trailer of any type hooked up. Thanks for taking the time to explore with it and posting your results. It looks like its a winning combo.
Martin
m.colley
Images: 83
Postby DrewsBrews » Sat Jul 02, 2016 9:59 am
Since you wouldn't need the trunk cam once hooked up, a wired setup could be designed to unhook the trunk cam and hook the same wiring to the trailer cam. Simple way to use one screen for both and no need to mess with multiple inputs.
DrewsBrews
Postby m.colley » Thu Nov 24, 2016 8:52 pm
143018143019
Shadow,
Now that you've had to chance to use your camera for awhile, how's it holding up? I've got some additional wiring to do soon and if I need to I can hard wire while I'm running my additional wiring. I know some cameras are using the digital wireless side which is suppose to eliminate interference and bad transmission.
Martin
m.colley
Images: 83
Postby Shadow Catcher » Thu Nov 24, 2016 9:17 pm
The only problem I ran into is that the camera has a rather wide angel, and I will construct a sun shade. I have not had any interference problems.
Images: 192
Postby capnTelescope » Tue Nov 29, 2016 7:18 pm
Shadow Catcher wrote: ... I will construct a sun shade.
Yeah, mine needs that, too. Shading the top quarter of the view would be helpful.
Brad
My Build
capnTelescope
Images: 364
