Opinions on a/c units for a 6 x 12 Cargo Conversion
Re: Opinions on a/c units for a 6 x 12 Cargo Conversion
Postby m.colley » Sun Apr 10, 2016 8:05 am
DaveMann wrote:
aggie79 wrote:. They allow air in (presumably outside air) for benefit (I assume cooling) of the condenser. Is this correct? Yes you are correct
Would inside air (which is cooler than outside air once the thing starts running) from a vent under the cabinet the ac is mounted in satisfy this requirement? It should, or you can create a intake vent to the exterior that would solve it as well.
You've all been a great help so far. I'm so close to finally "getting it".
Images: 83
Postby lacofdfireman » Wed Apr 13, 2016 12:04 am
I'm just starting a build and half way through decided to put in A/C and a generator. Before I was going to do a 12v system only. But where I live 110 degree days are not uncommon so I figured it's a must or I'll be miserable. My plan is to mount it permanently kinda like you see it where it sticks out the front and maybe 4-5 inches inside and build a box around the rear of the unit on the front of the trailer above where I build my tongue box. Also the box will have a drop down hatch for when in use so that the exhaust air can escape and the side vents can also take in air. Just trying now how I want to accomplish all this without making my trailer look to goofy.
Postby Iconfabul8 » Fri Jun 03, 2016 12:40 am
I realize I am a little late to this conversation, but If I am not mistaken, the air feeding the side vents of the Coleman trailer's AC was being brought in from the roof through what looks to be a fridge vent.
Postby noseoil » Fri Jun 03, 2016 7:57 am
I'm installing a window type 5K BTU Haier unit this weekend on my build, at least I hope it gets finished by Sunday night. It measures about 16" wide, 12" tall & 14" deep. On the model I have, the side vent slots are 9" from the back edge (the outside edge), the top slots are 8" from the back. Mine will slide out to only about 6" past the box edge so it lacks a completely open back, but there's enough side & top clearance inside the box opening to let the air be drawn in on the sides & top (to push it out through the back) with the fan running.
You have to allow for enough free airflow or it just won't run properly & efficiently. Did I compromise the airflow? Yes. Did I leave enough clearance for it to still work? Yes.
We did a test run last weekend & it works great. The temperature inside dropped from 86 to 64 in about 20 minutes, so it's getting enough free airflow.
We met a guy with a manufactured teardrop in Flagstaff, who said his air conditioner just couldn't keep up with the heat in Arizona. His installation has a roof type vent above the back of the AC unit, which is mounted in the footboard/galley wall & it sits in a box. It will let the heated exhaust air out through the roof vent, but no provisions were made to allow for a free intake of airflow into the box from the back side of the unit (at least from what I saw), so it basically just stews in it's own juices while running.
In any installation, look at the unit you're going to use before deciding where it will go. It needs an unobstructed airflow in the front for cooling in the cabin. Restricted ducts, lots of plumbing & bends take up room, reduce the airflow & create back-pressure the system was never designed to deal with. The small fans aren't strong enough to deal with a friction loss from plumbing. The same is true in the back for the heat exchange. If it can't draw fresh air from outside with the fan & then push it out the back, it will not work properly. It might work, but it won't work very well.
I see too many issues where people put an air conditioner in a box & expect it to work properly. If you put an air conditioner in a sealed box, plug it in and turn it on, it makes heat inside the box, not cold! Take it with a pinch of salt as I'm no engineer, but the units are designed to run a certain way & a lot of time is spent in the design to make it run properly. If you monkey with it, you may hurt the efficiency & function.
Images: 66
Users browsing this forum: tony.latham and 1 guest
