Wiring Check
Wiring Check
Postby RunnerDuck » Tue May 03, 2016 3:47 pm
I'm just starting to wire up my TD and would like to have a little check of my Ceiling Light/Porch lights plan.
I'm using three way switches for the ceiling light so I can switch them from either side.
Do you see anything wrong with this?
Ceiling - Porch Light Wiring.jpg (20.5 KiB) Viewed 448 times
Thank you,
RunnerDuck
Re: Wiring Check
Postby H.A. » Tue May 03, 2016 7:14 pm
:ead:
H.A.
Re: Wiring Check
Postby Shadow Catcher » Wed May 04, 2016 6:22 am
Our lights are marine LED and the switch is on the light, the outside porch lights also have their own switch. I have never thought it a problem. and it keeps the KISS principle :roll:
Images: 192
Re: Wiring Check
Postby blentz » Thu May 05, 2016 7:31 pm
3 way switches were hard for to understand until a old journeyman explained. On the comon terminals one get power the other, the switch to the light and the travlers between the switches. Never had trouble with them again. Looks like you have it.
Sent from my VS985 4G using Tapatalk
blentz
