fuse bar vs inline fuses
Postby mariannf » Tue May 17, 2016 11:21 am
Hi all,
Another question for anyone who can help.
I am planning on only having three loads in my build: fantastic vent fan, dome light, and 12 volt socket charger. Do I need a fuse bar or can I just use three inline fuses (one for each)?
thanks in advance!
mariannf
Re: fuse bar vs inline fuses
Postby 3GKnight » Tue May 17, 2016 12:24 pm
It doesn't really matter. Fuse blocks are handy as they're usually easier to access, easier to replace fuses, and a bit 'cleaner' for assembly. In-line fuses are floppy and difficult to attach in a clean way. There's not much of a price difference either. A 4-gang fuse block is ~$6 some places.
I'd recommend a fuse block. Much cleaner to install. Good luck!
3GKnight
Postby Shadow Catcher » Tue May 17, 2016 12:26 pm
My bet is that in the future you will want more circuits than you think you do. I found that out the easy way, I planned for it.
Images: 200
Postby H.A. » Tue May 17, 2016 2:53 pm
Juus.
H.A.
Postby mariannf » Tue May 17, 2016 4:25 pm
thank you all...fuse bar it is!
mariannf
