Shore power inlet.
Anything electric, AC or DC
Shore power inlet.
Postby blentz » Sun May 22, 2016 1:50 pm
I bought a nice power inlet from Amazon to install in my Teardrop. So I'm now getting to the point of finishing up the electrical system. I haven't bought a shore power cord yet but thought I would pick up a 30amp to 15amp adapter to run it while I'm finishing up. Well the problem I coming up against is the connector I bought for the Teardrop is a 30A twist lock and everything I find in the local bigbox store is not twist lock. My question what configuration is standard? Is there a NEMA number?
blentz
Re: Shore power inlet.
Postby Shadow Catcher » Sun May 22, 2016 4:00 pm
Do a search on 30A twist lock http://www.amazon.com/Foot-Power-Hubbell-Twist-Connector/dp/B008S2K552 and get the adapter.
Images: 192
Postby dales133 » Sun May 22, 2016 9:18 pm
Yea theres heaps avaliable on amazon.
You can even get the bare twist lock you can wire onto an extention cord.
I went all through this myself
dales133
Postby mustangcats » Sun May 22, 2016 9:25 pm
I had the same problem. I went to a local electrician's shop and they had the female connector that I needed. Wired it to a cord and I was all set.
mustangcats
Images: 18
Postby blentz » Sun May 22, 2016 11:55 pm
OK thanks guys. I had bought an outlet from Amazon several months ago and only now discovered it was a twist lock. Now it looks like that is what it should be. I ordered an adapter also a cord that has a twist lock at one end and regular 30A configuration at the other. So I should be OK.
Thanks for the help.
blentz
Postby Andrew Herrick » Mon Oct 24, 2016 12:31 am
I know it's an old thread ... but in case anyone is building a super simple electrical system and doesn't want/need 30-amp connector ...
The NOCO Genius GCP1 installs in about 5 minutes with a 2-inch hole saw. Only good for 15-amp power, but it eliminates any need for wire splicing or exterior waterproofing.
It's nothing fancy. No real security or twist-lock features or in-use enclosure. It's definitely not a one-size-fits-all solution. But if you want cheap, fast and easy, it's the best I've found. Good luck!
A few of my builds:
Andrew Herrick
Postby Don L. » Sun Nov 06, 2016 8:42 am
Shucks! I just rigged something up but would have bought that -NOCO Genius GCP1. I didn't know what to google for, I looked all over the web and the rv store sites but didn't see that or anything similar.
I suppose if my thing fails I'll get that.
Thanks for the link though.
Link to my foamie camper build viewtopic.php?f=55&t=67321
instagram #don_leister_violin.rva
Don L.
Re: Shore power inlet. input/output for simple 15amp cords
Postby working on it » Sun Nov 06, 2016 8:58 am
I wanted my shore-power input/output to be completely shielded from water. Only requires a good outdoor extension cord (or two; input/output). As long as the park power pole side has its' cover, no problems even in pouring rain. http://www.tnttt.com/viewtopic.php?f=30&t=61909&hilit=power&start=15#p1108486
2013 HHRv"squareback/simple" TTT, semi-offroad? 4x8, 2000+ lbs travel weight
  • 3500 lb Dexter axle w/brakes,
  • 27x8.5-14LT all-terrain tires (x 3),
  • LED lighting, triple fans. stereo inside,
  • A/C & heat, Optima AGM, inverter & charger(s)
  • extended-run, on-board, 2500w generator,
  • Coleman dual-fuel stove & lantern,
  • zinc/stainless steel front rack
[*]153929148599153928
working on it
Images: 432
Postby swoody126 » Sun Nov 06, 2016 8:53 pm
30amp twist lock components are common on portable generators like the ones used for construction sites
i think i got my last adaptor @ Northern Tool
sw
swoody126
Return to Electrical Secrets
