Wiring help please
Wiring help please
Postby vitya-velik » Mon May 30, 2016 3:50 pm
Is the fuse block the same as amp breaker box? I am using the wiring diagram below but only for 12v wiring system. Could I make my own ground block? How would I?
Are these all the things I need to wire my teardrop for 12v power with a solar panel.
100 watt solar panel.
Charge controler
2 12 v 35amp batteries
40 amp breaker
Ground block
Fuse block
20 amp fuses.
Master switch?
Then all my lights fan 12v outles and usb ports.
Sent from my LG-H343 using Tapatalk
vitya-velik
Re: Wiring help please
Postby tony.latham » Mon May 30, 2016 7:36 pm
I'd suggest two things: Move your DC circuit breaker to where the "8GA" print is, and use this type of fuse panel instead your 12V "Circut Breaker" and your ground block. http://www.amazon.com/Blue-Sea-Systems- ... fuse+block
I don't know what an "amp breaker box" is.
What roof fan are you using? My Fantastic draws 4 amps or less. I can't imagine you'd need 12ga.
Hope this helps.
Postby blentz » Tue Jun 07, 2016 9:40 am
I took a terminal strip used a flat jumper strip to connect all the terminals used an 8 gauge wire back to the 12v common to make a common connect point.
Sent from my VS985 4G using Tapatalk
blentz
Postby haha49 » Fri Jun 10, 2016 2:05 pm
Ground block can be a chunk of steel anything you can even use your steel trailer if you want that's what cars do use the car anything metal can be used as a ground it's insulated by the tires. Houses if you walk around them have a wire that goes into the ground so they're grounded to the actual ground
Amp brake is the same as a house brake just made for 12v. It's a switch so if something draws to much it flips over you could use a fuse instead. Matched to the type of wire you use so thin wire pulling 10 amps can melt since it gets hot thicker wire can do 30 amps before it's a problem. More amp draw bigger fuse or breaker. Cars use fuses instead. So you could go fuse box in line fuse or brake box
haha49
