Charging while at home?
Postby dogpound101 » Wed Jan 18, 2017 6:10 am
Still in the planing phase on electrical
If l have the pd4045 with the typical 30 amp
Plug at most campsites then what do I need at home to stay charged? Can I just get an adapter or do I need a 30 amp Circuit at home? Please excuse my ignorance
Doug
dogpound101
Re: Charging while at home?
Postby aggie79 » Wed Jan 18, 2017 8:20 am
I use a 30 amp female to 15 amp male adapter to charge while at home. I also keep an adapter in the teardrop in case the pedestal at the campground has a defective 30 amp receptacle and/or breaker. Our local Walmart stocks the adapters.
Postby noseoil » Wed Jan 18, 2017 8:37 am
Small solar panel for us, works even in cloudy weather.
137905
noseoil
Images: 669
Postby dogpound101 » Wed Jan 18, 2017 9:05 am
aggie79 wrote:I use a 30 amp female to 15 amp male adapter to charge while at home. I also keep an adapter in the teardrop in case the pedestal at the campground has a defective 30 amp receptacle and/or breaker. Our local Walmart stocks the adapters.
Thanks That's what I was thinking
So thankful for the abundance of knowledge on this site
Doug
dogpound101
Postby swoody126 » Wed Jan 18, 2017 9:12 am
being a welder has me w/ a larger service panel than the average Joe
that being said, i have installed an RV-30A plug at home and 4 of them at the barn(for mine & gatherings)
this way i can run all systems as if camping or when using my trailer as a GUEST HOUSE
IF you only wish to charge your battery pack while at home the above ^^ suggested use of adapters should suffice
just be careful when using adapters and maintain an awareness of the temperature of the wiring & plugs which can be a warning about potential unpleasant issues
as long as the wires & plugs remain cool everything should, SHOULD, be OK...
sw
swoody126
Postby Shadow Catcher » Wed Jan 18, 2017 9:57 pm
I made up an extension cord with the 30A female receptacle and 10 ga wire that plugs into a 20A dedicated plug in the garage.
