I need help with a battery and charging system
Re: I need help with a battery and charging system
Postby dmdc411 » Tue Feb 14, 2017 10:32 pm
This might be off the subject a little. I do not have a battery setup. I used (8 total) 12vdc LED rv lights, and a 12vdc Fantastic fan. I installed a small ammeter for reference during my build. Max amp draw is 7.5 amps worse case scenario, every light on, and the fan on high. My 12vdc source is a desk top computer power supply. Max output is 14 amps. Came across a how to on you tube before I started my build! No charger, no inverters needed.
dmdc411
