Pmullen503 wrote:The RC world has developed chargers for Lipo batteries that are DC-DC. You'd need a 200W charger similar to this:https://www.amazon.com/Battery-Balance-Charger-Discharger-Digital/dp/B07HQ651SB/ref=sr_1_13?s=toys-and-games&ie=UTF8&qid=1545325567&sr=1-13&keywords=200W+lipo+charger Most have a lead acid setting. You could use the same charger with a 12V power supply when you have shore power.
MtnDon wrote:I think I see a potential upside to using an inverter in the TV and then a battery charger in the trailer for the trailer battery. If we run heavy gauge wires (pos and neg) from the TV to the trailer to charge the trailer battery is there not a danger of overcharging the TV battery if the trailer battery needs lots of charge?
Assuming the TV battery is near to full charge as a good TV battery should be most of the time, and that the trailer battery is low because we've been camping a day or two, when we take off down the road does the energy being put out by the TV alternator know to go mostly to the battery that needs charging? That would be the battery in the trailer. A battery that needs a good amount of charge needs a higher voltage applied along with the higher current. The TV battery, fully charged after driving a few miles, does not need as high a voltage nor much current.
The regulation system built into the TV alternator cannot do two different things at the same time, can it? So what happens? what battery does the TV alternator regulator read? It seems to me that one battery is not going to be getting its optimal charge. Will the TV battery be overcharged or the trailer battery be undercharged?
That's why I can see the potential value in what seems like an overly complicated idea. Thoughts?
Andrew Herrick wrote:...........
It sounds like it CAN work, but it's not optimal. Not enough amperage to charge a battery quickly, and the wrong charging algorithm for most automotive lead-acid batteries.
PMullen, I'd love to hear more about your idea. Why do you prefer this DC-to-DC RC charger over an auxiliary 12v charge line (as recommended by others) and/or a dedicated 120v battery charger (when on the grid)?
...because their high end AGM batteries are not getting fully charged...
KTM_Guy wrote:My question is he said golf cart batteries, those are usually 6 volts. I'm sure they are wired is series for 12 volts. But what I have been reading is you should charge your batteries at the battery rated voltage. Noco who makes high end chargers even says to charge batteries wired in parallel should be charged individually.
