NEC Waterproof Solder Connectors
Postby StrongFeather » Sun Jan 20, 2019 1:42 pm
Anyone use these?
https://www.youtube.com/watch?v=7Wh5gM8GM70
I searched the site and couldn't find any comments about them, so I thought I'd ask. They look quick, easy, effective and reasonably priced at about $.20 each.
:beer:
Build Journal viewtopic.php?f=50&t=71138
Composite Panel Construction Technique viewtopic.php?f=21&t=71192
If women don't find you handsome, they should at least find you handy.
~Red Green
StrongFeather
Images: 30
Re: NEC Waterproof Solder Connectors
Postby Kaz » Sun Jan 20, 2019 1:49 pm
I wouldn't waste the money. I have always just soldered my connections and used marine grade shrink tube. I've had insulation dry out and crack before the splice went bad. Just my 2 cents worth.
Kaz
Kaz
Images: 122
Postby KTM_Guy » Sun Jan 20, 2019 3:44 pm
Looks easy when you have room to work and can twist the wire to get even heat. But how do you twist the wire and hold the heat gun in a tight space where most likely wires are? And how many butt joints would you have? Leave the wires long and them cut to length. And don’t have any connections that you won’t have easy access too.
Todd
KTM_Guy
Images: 193
Postby GuitarPhotog » Sun Jan 20, 2019 11:41 pm
Connectors are the primary failure point in any electrical circuit!
Making a good solder joint is harder than making a good crimped joint with a proper tool.
It is possible, regardless of what many claim, to make a good, reliable crimp joint with a hardware store tool. But it takes almost as much practice as learning to make a proper solder joint.
I have been making solder joints for more than 1/2 a century. I made my living soldering. I've also been making crimp joints for almost as long.
I wouldn't bother with waterproof solder connectors unless the joint was subject to water immersion. A good shrink wrap will protect a good solder joint from all but the most harsh conditions.
My $0.02 worth
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby swoody126 » Mon Jan 21, 2019 8:09 am
i aready drank the Kool-Aid ;-)
had a custom boat trailer built and watch'd the guys use the waterproof crimp connecters
the young man who was doing the work called me from the wings where i had been watching the build and told me to get up close and watch
he used a Bic lighter w/ finesse to do the sealing and showed me how to watch for the heat activated sealant to ooze from the ends ever so slightly to know when the connection was sealed
those things worked w/o failure for the 5 years i owned the boat which got dunked reguarly in both fresh and salt water
saw the commercial for these new connecters and ordered up a bag of each size
have only played w/ them so far and can tell you not use a propane torch
it gets too hot too fast
when electjuicity is available use a heat gun
in the field i'm going to a butane match or Bic(both of which i carry in my kits)
their main job is coming to fruition and they will be used on this new boat trailer which is destined for both fresh and salt water dunkings
when it comes to electrical connections i consider dunking in salt water to be an acid test
i'll let you know if they fail
sw
swoody126
Postby tac422 » Mon Jan 21, 2019 10:59 am
I used these many years ago in the military, they are great !
I'll definitely be buying some of these …
Thanks for your post !
123715
The Big Pink
tac422
