thoughts on
thoughts on
Postby Wellcraft290 » Mon Nov 18, 2019 9:09 am
whiteoak26 youtube vid of camper electrical system? i like it and seems relatively easy in design.
thoughts? suggestions? just confused on teh converter hooking up to the blue bus.
Wellcraft290
Re: thoughts on
Postby tony.latham » Mon Nov 18, 2019 10:54 am
thoughts?
I don't understand why he is using welding cables. That looks like gross overkill.
Glad I don't need anything more than 12 volts.
It is camping, after all.
:thinking:
I never did see a blue bus bar.
p.s. if you want to get more discussion, you might insert the Youtube here.
Re: thoughts on
Postby Wellcraft290 » Mon Nov 18, 2019 11:44 am
sorry here you go part one.
https://www.youtube.com/watch?v=HeNZgiKPFnA
right under the transfer(fuse panel) box off the shore power input
and I agree welding cable way too much lol
Wellcraft290
Re: thoughts on
Postby tony.latham » Mon Nov 18, 2019 12:23 pm
Wellcraft290 wrote:sorry here you go part one.
I still don't see it and his system is beyond my 12 volts. I just don't have the brain amps.
Have you asked the poster about it on Youtube?
T
Re: thoughts on
Postby Wellcraft290 » Mon Nov 18, 2019 12:30 pm
https://www.youtube.com/watch?v=oj0we2v3d3s
at 3:15 in this video
see has red on the top right and black on the left on the same post?
Wellcraft290
Re: thoughts on
Postby tony.latham » Mon Nov 18, 2019 9:25 pm
I don't know what he has going on there. Here's how it should be wired:
He must be running a washer and dryer in that beast.
Re: thoughts on
Postby RJ Howell » Tue Nov 19, 2019 9:24 am
As soon as he said AC unit.. he's past what I require.
I say this quite often, yet bares saying again.. First do a power audit and figure out what you need. Here's a sample of mine:
I'm 12v based. I do have a 30amp service with a converter/charger, yet rarely used.. For me, it won't even be in my next build. You need to decide first what you need/require and what sort of system to use.
He kinda bothered me when he stated his battery bank at 300ah.. That may be what the rating may total to, but no where near what his usable amps are.
Is his system solid? Seems to be.. Is it something you require? Only you can answer that. Way over-kill for me.
RJ Howell
Images: 34
Re: thoughts on
Postby Wellcraft290 » Tue Nov 19, 2019 10:36 am
I agree I would only do 1 100 AH battery but do camp where there is shore power.
So I like the idea of a converter. but you can use the converter and hook to the blue bus fuse positive to positive and it will back feed to charge the batteries? that is what I am trying to figure out more then anything.
Wellcraft290
Re: thoughts on
Postby tony.latham » Tue Nov 19, 2019 11:33 am
...and hook to the blue bus fuse positive to positive and it will back feed to charge the batteries?
I finally figured out you were referencing the Blue Seas fuse block and not a blue-colored bus. But yeah, continuity is continuity.
Re: thoughts on
Postby Wellcraft290 » Tue Nov 19, 2019 1:15 pm
thank you. I am dangerous but have an idea of what I am doing. educating myself.
Wellcraft290
Re: thoughts on
Postby Rainier70 » Sun Dec 08, 2019 9:19 pm
He does have it hooked up to the positive and negative poles of the Blue Sea distribution box. The part that is confusing is the color of his wire that goes to the top negative post is red when all the other negatives are white or black. If you look at the picture at about 3.20 you can see the relatively short positive wire that he has going directly to the bottom of the Blue Sea box from the converter. It appears to be red also which really makes it confusing. Coloring or painting part of the negative wire to show its polarity would have helped.
Rainier70
Images: 244
Re: thoughts on
Postby Wellcraft290 » Mon Dec 09, 2019 3:15 pm
ty i thought I was going crazy for some reason.
Wellcraft290
