DoctahDeane wrote:Gets good reviews. My set up will be straightforward. Not sure about solar but for now, plug in to onshore power, recharge battery - basic stuff. If I could get a couple of nights to begin with, that'd be great. Looking for recommendations for a solid, simple battery charger too, and would welcome any pointers. Thanks!
https://www.amazon.com/Vmaxtanks-Vmaxslr125-rechargeable-Solar-Inverters/dp/B00ACNO2AO/ref=sr_1_1?gclid=Cj0KCQiAwP3yBRCkARIsAABGiPrODmGN_GZFS6zgsWaS7V5OK5ZhPQKM1kIujZ-Exnk-RS8KTAHMgWwaAh7EEALw_wcB&hvadid=182723154675&hvdev=c&hvlocphy=1027360&hvnetw=g&hvqmt=e&hvrand=9078824252576480843&hvtargid=kwd-30701459935&hydadcr=24629_9648897&keywords=125ah+deep+cycle+battery&qid=1583337712&sr=8-1#customerReviews
You should be able to find a similar 100+AH 12 VDC deep-cycle AGM battery for half that price!
tony.latham wrote:You should be able to find a similar 100+AH 12 VDC deep-cycle AGM battery for half that price!
I dithered for days, weeks, and months over which battery to buy for my new build. In the end, I chose a Group 24 from Vmax. It was about the same expense as buying one from a local tire/battery place for a branded battery that was made by who-knows? I almost pulled the plug on a cheaper Chinese battery. Of all the battery manufacturers, Vmax has one of the top reputations.
Ask me in six or eight years how it did.
But if right now if I was doing is again I would go lithium.
tony.latham wrote:But if right now if I was doing is again I would go lithium.
Can you recommend a multimeter or source and also wondering how that gets wired in to the overall setup? Does it just run to the fuse box or does it need direct connect to battery?
tony.latham wrote:Can you recommend a multimeter or source and also wondering how that gets wired in to the overall setup? Does it just run to the fuse box or does it need direct connect to battery?
I do hope my book helps. If you wouldn't mind giving it an honest review on the big A, I'd greatly appreciate it.
