DoctahDeane wrote:Is there any sort of airlock/clamshell port that I can use to run the solar cable into that box so I can attach to the battery?
DoctahDeane wrote:The other question is about some sort of 12v cigarette plug dongle that might be attached to the cabling ends so that I could run direct from the panel to an electric cooler (cooler in the shade, obviously)?
GTS225 wrote:DoctahDeane wrote:Is there any sort of airlock/clamshell port that I can use to run the solar cable into that box so I can attach to the battery?
Yes. There's a fitting available that uses common size electrical knockout punches that has a rubber seal in it. Install it into the wall of the electrical box, run your cable through it, and tighten down the gland nut. That squeezes the rubber onto the cable, making a waterproof seal.DoctahDeane wrote:The other question is about some sort of 12v cigarette plug dongle that might be attached to the cabling ends so that I could run direct from the panel to an electric cooler (cooler in the shade, obviously)?
Yep, that's available, too. If you have any automotive stereo shops around, they should be able to fix you up with a quality, 12vdc power port that can be panel mounted. (Do not get a cigarette lighter socket! They are cheaply built, and not designed for long term current consumption.) My personal suggestion would be to run a fused lead from your electrical box to your galley. A convenient mounting point for the port, and you've got your outlet for the cooler. (It could also be used for cell charging.)
Roger
John61CT wrote:DoctahDeane wrote:Is there any sort of airlock/clamshell port that I can use to run the solar cable into that box so I can attach to the battery?
Indeed called clams in the marine domain
https://www.defender.com/category.jsp?p ... id=2289996
other related keywords
water-tight bulkhead split Cable Glands / Cable Bushings / Wire Seal / Cord Grip Connectors / Strain Relief
AARGH NO!
Standard ciggie sockets are IMO a dangerous abortion, avoid like the plague for anything important, or that you use regularly. Never more than 5-6A and only for short periods, as in a few minutes. Even then they are risky, an inherently poor design!
Blue Sea has a nice socket design that twist-locks with the matching plug, but will also accept standard ciggie plugs for smaller (<10A) loads.
Also the BMW/ Hella/ Merit/ Powerlet "Euro-style DIN" (ISO 4165) style is very robust.
Anderson plugs for high amps, for me my standard, for almost all power connections.
If you standardize on one of the last two types, there are adapters for guests, temporary use of devices with standard ciggie plugs.
Trebor English wrote:Two things.
Thing one: if you get a portable panel they usually come with a charge controller attached to the panel. If you get a panel and a controller and mount the controller near the battery you should not connect stuff to the panel wire. The power needs to go through the controller first.
Thing two: by electric cooler do you mean a Peltier thermoelectric cooler? Those take a huge amount of electricity and don't keep cold enough for safe storage of food. Typically they cool to 30 degrees below ambient. At 90 degrees your food is 60.
