DoctahDeane wrote:I have each individual item in my trailer on a separate 7.5A fuse in the fusebox. My water pump is on a 15A. There's nothing more i plan to add at this time, except a solar panel but that will not affect the fusebox. But it got me wondering about how to handle the addition of new items. How is that handled best? Does it ever make sense to have two devices that are never used at the same time on one fuse? Or, in the case of my cabin, I have two small reading lights for example (LED). Each has it's own fuse. Is it wrong, potentially, to have them both on the same post/fuse? Hard to imagine they'd be peaking out as they are LED and small. Or, big picture, does it make any sense to add a second fusebox? Like I said no plans to add anything now, but if I do in the future, I would like to do it safely.
MtnDon wrote:The nice thing about having two circuits for interior lights, is that IF one fuse does blow, you should still have the other light(s) working so you can still see.
troubleScottie wrote:You might want to add 12vdc outlets. Running wires while building is easy. Running wires after completion is often difficult and aesthetically unpleasing. Most wires are in the floor, walls or ceiling. Adding outlet means you can add in other items. Not pretty, but connected.
Also you left out a fan. That might be the most important.
saltydawg wrote:my wiring plan is a fuse for each of the below
ext lights
int lights
water pump
power points
fans
heat when I do it
I do have a 12 point fuse box, so if I need to split stuff up I can
I plan on a master switch bank with a switch for each of the above, and if the water I get has the ability for a remote switch one for it too.
heat when I do it
tony.latham wrote:heat when I do it
Electric heat?
Users browsing this forum: No registered users and 21 guests
