https://www.facebook.com/photo?fbid=102 ... 0306028065
We are about to install our Power Converter and I have a couple of questions. I posted a photo of the panel and my plan to the FB group but seem unable to post it here. I made an attempt to post the URL above so we will see what happens.
I have been through tnttt.com and saw the excellent PD4045 wiring guide but it is silent on a couple of issues and the box has changed since then as well.
1. Is the battery neg connection block connected to anything else in the box or do I need to jumper it to the GRND bus?
2. I figured this one out but would welcome confirmation - Shore power hot comes into the box and is supposed to go to a 30A breaker. I now know that we are basically reverse feeding the AC bus through this breaker and it is ok, at least with the breaker that we purchased.
3. I figured this one out but would welcome confirmation - The converter section power is supposed to run through a 15A breaker. I now know that the reverse feed into the main breaker powers up the breaker bus and that I am then to connect the black converter power wire into this breaker.
4. I don't know the significance of the two red DC circuits in the first two DC fuse positions, are they different somehow and if so, how? It would appear, and has been mentioned by another builder, that the two red circuits are heavier wire and therefore higher capacity. I see no specs mentioned on this in the PD manual. Does anyone have any further info on this?
5. In reading tnttt.com it seems that the Green Gnd bus connects to the trailer ground. Can this be the same lug that the trailer lights use?
6. When I run a DC circuit I am guessing that the Red wire on the device will connect to one of the black wires coming out of the converter. Then the black wire from the device will home run back to the green bus bar. Do I have this right?
7. Is it correct that the negative terminal on the battery is also run to a grounding lug on the trailer?
Hopefully someone in the group is able to help a bit here and is using the same power converter.
Thanks,
Jim
