Elex Plan Review-Thank you!
Postby Capebuild » Mon Mar 29, 2021 7:43 am
Hello. I'm beginning to understand how my electrical plan might come together. I've posted a few images below. I'd really appreciate
any thoughts people could share and confirm if this plan looks like I'm going about this the correct way. I still have questions about the
batt to batt charging (TV battery charging the trailer battery) as I don't want to compromise my Subaru's alternator, so still researching that.
There will also be a battery monitor and a solar charger monitor located in the galley section of the trailer.
I also realize the MPPT solar charger may be a bit larger than what's needed for the 200 watt panel configuration and I could probably go with a 100/20 instead of the 100/30.
I realize this may be a lot to look at and give your thoughts ....so know that I do appreciate your help.
Thank you.
John
elex layout in placejpg.jpg (279.66 KiB) Viewed 970 times
elex schematic_3.29.21.jpg (158.43 KiB) Viewed 970 times
10 foot trailer assembly_3.29.21G.jpg (179.81 KiB) Viewed 970 times
Capebuild
Images: 129
Re: Elex Plan Review-Thank you!
Postby John61CT » Mon Mar 29, 2021 8:48 am
20A * actual Vcharge give max output from the SC
So 13.8 is 275W
14.9 is 298W
Going higher (overpanelling) gets more value out of the SC
Up to 10-15% will only affect very short & rare peak outputs, increasing the critical **average** daily output.
Ideal for shade handling is 1 panel per SC
John61CT
Postby saltydawg » Tue Mar 30, 2021 7:50 pm
Okay I would suggest instead of different fuses for every charging source, just take them to a fuse ( one each ) on the blue sea fuse panel. Same with the positve connection for the meter, just take it to the fuse block.
Also while I love voctron stuff, look at the renogy dual source charger. It combines the dc2dc and mppt solar into one unit. Less wiring, less things to fail, but less redundancy
https://www.renogy.com/dcc30s-12v-30a-d ... with-mppt/
Scott
Lost in Maryland
saltydawg
