Renogy DC On-Board Charger
Postby cjlangellier » Wed May 05, 2021 8:15 am
I'm curious if any of you have any direct experience with the Renogy DC On-Board charger? I'm wanting to have solar and DC-DC charging options and this seemed like a clean, cost effective way to combine both systems into one. There are a couple things I'm curious about. How much heat does this thing put off? I notice it has a pretty large heat sink on the back of the box. Do I need the bluetooth module to customize charging profiles for different battery types? Down the line, I intend to upgrade to a lithium battery.
At present, I'm planning on the following electrical system:
-AGM 100ah battery
-175W Renogy flexible solar panel
-Progressive Dynamics PD4045 converter/power center (no inverter. we don't run much 110 power and have a backup generator if we get in a tough spot boondocking)
-Renogy DC On-Board 30A charger with built in MPPT controller
If I've done my research appropriately, I should have the following charging options.
-DC-DC when towing
-Solar when Boondocking
-Shore Power when conventional camping
Cody - Westmont, IL
5x11 Teardrop
http://www.tnttt.com/viewtopic.php?f=50&t=73740
6x12 Cargo Trailer/Ice Shanty/Toy Hauler
http://www.tnttt.com/viewtopic.php?f=42&t=73743
cjlangellier
Images: 332
Re: Renogy DC On-Board Charger
Postby saltydawg » Wed May 05, 2021 4:36 pm
That charger is a good one, you do need the dongle if you want custom charge profiles, but their lifepo4 curve is a decent one. It will put off heat and get warm, just make sure you have some airflow ie dont mount it in a closed box.
Edit it is externally changable to built in battery types, its just custom that take the dongle.
Scott
Lost in Maryland
saltydawg
Postby cjlangellier » Wed May 05, 2021 8:33 pm
saltydawg wrote:That charger is a good one, you do need the dongle if you want custom charge profiles, but their lifepo4 curve is a decent one. It will put off heat and get warm, just make sure you have some airflow ie dont mount it in a closed box.
Thank you! This was exactly the info I was looking for. I went ahead and placed an order with Renogy. They have a great sale going on this charger and the flexible panels. Plus I was able to find an additional $50 off coupon code.
Cody - Westmont, IL
5x11 Teardrop
cjlangellier
Images: 332
