Wiring Switches
Wiring Switches
Postby Capebuild » Thu Oct 07, 2021 3:34 pm
I'm getting ready to wire in some switches. I've got a limited amount of space created in the side wall to house these
switches. The switches I'm using have blade contacts sticking out from them which I was going to crimp the appropriate blade
connectors to the wire I'm using. However with these blade connectors sticking out from the back of the switches and add
the wire to it, the switches will not fit into the space created for them (lack of depth).
Asking if anyone has bent the blade connectors at right angles.... so crimp on the wires and bend the connector where the wires hook into
and bend that at 90 degrees from where the blade receiver is? Or open to other suggestions? I'd rather not add a spacer block of wood
to bump out the switches to create more room (but may have to resort to that). I thought of enlarging the holes on the switch's blades, soldering
the wire on (with shrink tubing) but with 14 gage wire, the holes get kind of large leaving not much meat on the switch's connection blade.
Or maybe there's some other blade connector I'm not aware of.
This must be a common issue....just curious how others deal with it.....
Thank you for any suggestions!
John
Capebuild
Images: 129
Re: Wiring Switches
Postby edgeau » Thu Oct 07, 2021 4:09 pm
I have bent the connectors with small needle nose pliers. I recommend bending before crimping as sometimes they snap off.
Sent from my Pixel 3 using Tapatalk
edgeau
Re: Wiring Switches
Postby halfdome, Danny » Thu Oct 07, 2021 4:55 pm
John, I make a small wood block to house the switches so no bending necessary.
The switch blocks add a point of interest since I make them in an exotic wood combination.
I'll submit an image later.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Re: Wiring Switches
Postby TimC » Thu Oct 07, 2021 7:12 pm
I've bent both the blades on the switches and the terminals. They do occasionally break but I haven't had trouble if I only bend once.
Even though bent I add depth with a piece of wood the appropriate thickness.
Tim
Niagara, WI
TimC
Images: 736
Re: Wiring Switches
Postby pchast » Thu Oct 07, 2021 7:58 pm
I used wood blocks to improve spacing, however, You can also get right angle connectors. :thumbsup:
pchast
Images: 97
Re: Wiring Switches
Postby dmdc411 » Thu Oct 07, 2021 8:17 pm
There are crimp on connectors where the wire is at a right angle to the plug. I've never used them, so I can't say much more! Good luck!
Sent from my SM-G970U using Tapatalk
dmdc411
Re: Wiring Switches
Postby halfdome, Danny » Thu Oct 07, 2021 8:28 pm
Here's my way of dealing with thin walls and switches. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Re: Wiring Switches
Postby MtnDon » Thu Oct 07, 2021 8:46 pm
MtnDon
Images: 24
Re: Wiring Switches
Postby saltydawg » Thu Oct 07, 2021 9:07 pm
Don has the best idea, but I just solder em on flat. Not drilling them out.
I have found bending and twisting on the crimps make them loosen, so solder it is.
Scott
Lost in Maryland
saltydawg
Re: Wiring Switches
Postby mountainminded » Thu Oct 07, 2021 9:09 pm
Google “ Flag Terminals.” They are made for the job. The very tip of your ratcheting crimp tool should accommodate them nicely. I use the “non-insulated” flag terminals and the matching non-insulated die set on my crimper.
-Rob
168078
Rob Walker, Trailers4Two Bend Oregon
mountainminded
Images: 58
Re: Wiring Switches
Postby Capebuild » Fri Oct 08, 2021 3:09 am
halfdome, Danny wrote:Here's my way of dealing with thin walls and switches. Danny
Beautiful, Danny. Thank you for showing me. Looks like a framed work of art.
Just soldering the wires on, as Scott suggested is a good suggestion. I like that.... with some shrink tubing.
Thank you all for the suggestions. After my original post I had googled right angle connectors and see there is such a thing. So thanks for suggesting those.
In the end I think any kind of connector is going to take up more room than I'd like if I keep the current opening I've created.
Thinking about this I may just add a bump out similar to what Danny has.... but thank you all again for the feedback.
John
Capebuild
Images: 129
Re: Wiring Switches
Postby friz » Fri Oct 08, 2021 5:37 am
Anther option would be to solder direct to the terminal. I had limited space in my under shelf pods so every connection in them is soldered and heat shrinked.Image
The "Sin Bin"
150133
friz
