Solar charging question
Postby nsfr1206 » Sun Mar 13, 2022 5:08 pm
I’m thinking about adding solar and a charger to my build. At this point I have a charger hooked to battery and when I am on shore power or if I’m using a generator it will charge from my 110.
My question is what happens when I have solar power coming in and I’m on 110 also. Do both chargers attempt to charge the battery? Do I need to have a switch where I take one out of the system? Help me get my head around this probably simple problem….
nsfr1206
Re: Solar charging question
Postby nsfr1206 » Sun Mar 13, 2022 5:57 pm
After reading some more I see that the two charging systems won’t really affect each other and both can be hooked up and used simultaneously. If this is bad info please let me know.
nsfr1206
Postby John61CT » Mon Mar 14, 2022 8:48 am
Yes no problem.
Similar charge profiles AMAP
John61CT
