SolarEntry Gland Questions
Anything electric, AC or DC
Postby Capebuild » Wed Apr 13, 2022 5:55 am
I've got a few questions regarding the entry gland and solar wiring:
1) The solar wires that exit my roof are probably a bit short in length to reach the panels (once I get them installed). Is there a way to extend their length.... like maybe using an MC4 connector to add a spliced wire...... is that an okay way to lengthen the cables?
2) Is using butyl tape the best way to seal the gland to the aluminum surface? I'd be interested to hear how other's have done it.
3) I imagine most of these entry glands are kind of the same.... but are there recommendations of a certain brand?
Thanks very much.
John
Capebuild
Images: 129
Re: SolarEntry Gland Questions
Postby tony.latham » Wed Apr 13, 2022 11:03 am
I had to splice one of my cables aft of the gland. Solder and heat shrink. There was no need to throw an MC4 in the mix.
I used Lexel to seal. No issues. I think butyl tape needs a bit of pressure on it to get a proper seal.
Postby flboy » Wed Apr 13, 2022 11:22 am
I can tell you how I did it and it has been working out well so far.
1) I did extend Solar panel cables using MC4 connectors and additional wires as needed on my 6x12 build. Used 2 to 1 MC4 connectors as needed on the roof side and only ran 2 wires through the gland.. The 2 wires I bought at the length needed also had MC4 connectors and mated on the 2 to 1 connectors. The 6x12 build just has qty 2 210 watt panels that are side by side. Very easy.
On my 7x18 build I just cut off MC4 connectors and extended (spliced) wires as needed to a junction box before I went through the roof with 2 wires, but I have 8 panels on that build over a much larger area.
2) I used butyl tape to seal , but then I used self leveling Dicor over the screws and seams as a top seal. I do that on any roof top gland, vent, or etc..
3) I don't know about the brands. I think I used a Camco brand and they have been good so far. They all seem similar. Just have to get the type you want. If possible, mount so the entry point on the gland faces the rear of the camper such that driving wind isn't trying to force water down the entry point.
Hope this helps.
Sent from my SM-N970U using Tapatalk
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby Capebuild » Thu Apr 14, 2022 8:33 am
Thanks Tony and flboy for your thoughts.
John
Capebuild
Images: 129
Postby bdosborn » Thu Apr 14, 2022 6:27 pm
I just finished the scary job of drilling a 1" hole in the new van roof for the PV wires to enter. I have two different arrays on the roof with 4 wires coming in and I didn't like most of the entry glands on Amazon. I found this at a van parts site:
Solar Entry Puck
Super easy to install, screws in securely and best of all, no leaks (so far). It even includes the calk for around the cables.
Images: 772
Return to Electrical Secrets
Users browsing this forum: No registered users and 29 guests
