inverter and shore power transfer switch
Postby goldenoak » Thu Jan 12, 2023 12:03 am
What kind transfer switch can be used to bypass the inverter when plugged to shore power and best way to be wired.
goldenoak
Re: inverter and shore power transfer switch
Postby Onajourney » Thu Jan 12, 2023 10:08 am
Here is what I got. Note that is only 20A but it works for me as I am not exceeding 15A.
https://www.amazon.com/gp/product/B07SKNMY9P/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Onajourney
Images: 181
Postby goldenoak » Thu Jan 12, 2023 12:41 pm
I was looking on this110V Dual Power Automatic Transfer Switch Dual Power Generator Changeover Switch 50HZ/60HZ (2P 63A Blue) https://a.co/d/0FHtoh9
goldenoak
Postby Onajourney » Thu Jan 12, 2023 1:54 pm
Not sure why you would need an ATS but interesting. I never saw one that small before and cheap.
Onajourney
Images: 181
Postby kmack67.km » Fri Jan 13, 2023 6:16 pm
I have only one limited circuit that I run off the inverter. It is connected via a pigtail extension (the plug end of a heavy duty extension cord) that I either plug into the inverter or a dedicated receptacle that is connected to the shore power supply along with the rest of the circuits. It may not be the slickest solution but its simple and it works.
Hope this helps,
Kevin
kmack67.km
Postby Mark Gunter » Mon Jul 10, 2023 1:50 pm
I used an unusual solution: I wired separate receptacles throughout. Shore power AC is accessed through white receptacles. With a flip of a switch, the inverter powers black receptacles if ever there is a need for AC power while boondocking.
I'm a happy man, I love my life!
My Gunter Li’l Standy build journal:
https://www.tnttt.com/viewtopic.php?f=50&t=75291
Mark Gunter
Images: 211
