by madjack » Thu Mar 23, 2006 8:18 am
...whenever you have a 2 battery system, the batteries should either be isolated from each other or bought at the same time...the weaker of the two batteries will pull juice from the other and cycle back and forth, discharging each other...also as George stated, you will need 6r8 gauge wireing to act as a supply line between the vehicle and camper to avoid voltage loss actoss the run
