madjack wrote:...it requires special precautions to handle... put in a cooler with food stuffs, it will freeze 'em up solid... put inna cooler which will be opened and closed regularly will result in it sublimating(melting) fairly quickly...there are uses for it which includes transporting frozen foods but it really doesn't work very well for daily use...
Toytaco2 wrote:...It didn't freeze the food (not in the cooler long enough) ... That "carbon burn" to the tongue was present in all of the fresh food... I'll never use it again except maybe to transport frozen foods.
madjack wrote:using some sort of sealing tape(duct, box, etc) put a wrap or two around the opening of the cooler...
caseydog wrote:madjack wrote:using some sort of sealing tape(duct, box, etc) put a wrap or two around the opening of the cooler...
BOOM. Nobody will get hurt, but it might scare the pee out of the wifey.
CD
caseydog wrote:BOOM. Nobody will get hurt, but it might scare the pee out of the wifey.
I tried dry ice once, and it was a waste of money. And, it will turn to gas quickly if you open and close the cooler.
I would just plan to replace your regular ice on a regular basis. It only takes a few minutes.
Ratkity wrote:caseydog wrote:madjack wrote:using some sort of sealing tape(duct, box, etc) put a wrap or two around the opening of the cooler...
CD
In the lab on a boring day, we'd seal dry ice pellets in eppendorf tubes and hide them in people's desks. Eppendorf tubes are tiny little plastic tubes with snap caps attached. It wouldn't take long for the pellet to turn to gas and POP! I would suspect the cooler would make a bigger bang unless you unplugged the drain hole for ventilation.
If, by chance, you use the duct tape method.. can you please have the video camera ready? I bet that one would go viral in youtube in short order!!
Hugs,
Ratkity
Martini wrote:I do hope we get a report on how this works out.
caseydog wrote:Martini wrote:I do hope we get a report on how this works out.
Well, the condom fills with gas and get's REALLY huge.... oh, do you mean the cooler?
CD
Users browsing this forum: No registered users and 26 guests
