Propane on the tongue of a Teardrop?
Postby tscarbroughdc » Wed Feb 19, 2014 3:13 pm
I'm starting to think that I want to buy cooking accessories and lighting accessories that run off of propane.
Do any of you have two 20# propane tanks on the tongue of your teardrop?
I really want to do that but am a little nervous about having them at the head of my bed! Haha
Any input pro or con would be appreciated because I am thinking about buying a mount for the tongue of my camper.
Thanks.
tscarbroughdc
Re: Propane on the tongue of a Teardrop?
Postby absolutsnwbrdr » Wed Feb 19, 2014 3:39 pm
I've heard that sometimes you can get stopped going through tunnels that have restrictions on explosive gasses. That's the only reason I'll keep my propane tucked away inside.
Zach
absolutsnwbrdr
Images: 405
Postby GuitarPhotog » Wed Feb 19, 2014 4:39 pm
I have my 20# tank of propane on the tongue of my teardrop. I have never had an issue going across bridges or tunnels in my travels. I prefer to have my propane tank out in the open rather than inside the truck or trailer.
Be aware that it adds directly to the tongue weight, ~17 lbs for an empty tank and ~20 lbs for gas adds 37 lbs directly to the tongue weight.
<Chas>
GuitarPhotog
Images: 55
Postby tscarbroughdc » Wed Feb 19, 2014 4:50 pm
Wow. Well it looks like it would be easiest to buy the mounts and just mount two 20# tanks to the tongue but that is a lot of weight! I didn't think about that. My trailer is already tongue heavy. But maybe when I put the battery and all in the back it will even out some
tscarbroughdc
Postby KCStudly » Wed Feb 19, 2014 5:04 pm
The GW Bridge in NYC is a double decker and propane bottles are only allowed on the upper deck. Not good to contain a rapid expansion.
Images: 8116
Postby Shadow Catcher » Wed Feb 19, 2014 6:55 pm
I have a single 25# tank which holds 6.76 gallons a 20# tank holds 4.7 gallons. Ours gets used for a three burner cook top, water heater and gas grill and it used only a couple of gallons in the eight days on the North shore of Lake Superior a single 20# or even a 10# would be sufficient.
109122
Images: 193
Return to Camping Secrets
