wing table
wing table
Postby superdad88 » Tue Feb 02, 2016 5:46 pm
I think that's what they are called. I was looking at putting one on my TD. Can someone point me in the direction as to where to buy the hinges ect...
superdad88
wing table
Postby vincigj » Tue Feb 02, 2016 5:58 pm
I bought mine from vintage technologies. Search "teardroptrailerparts.com". Ht15 table mounting brackets.
vincigj
Re: wing table
Postby Gunguy05 » Wed Feb 03, 2016 2:49 pm
Also search amazon. I bought mine there as it was much cheaper. "Patrick Metals 164922 30" Table SupportĀ "
Brian
Gunguy05
Images: 6
Re: wing table
Postby vincigj » Thu Feb 04, 2016 11:31 am
Yes I found those also. They don't match. Guess how I know?
vincigj
Re: wing table
Postby PaulaB » Mon Apr 25, 2016 6:20 pm
superdad88 wrote:I think that's what they are called. I was looking at putting one on my TD. Can someone point me in the direction as to where to buy the hinges ect...
I bought mine fromhttp://www.rvwholesalers.com/parts/products/table-support-31-1226 RV Wholesalers. They have adjustable table legs too. The hinge is $7.99.
Now would someone kindly direct me to info on making the tables? Types of materials used and what works well along with some photos would be great. I want lightweight and very durable. Has anyone used aluminum or stainless to sheath the top?
PaulaB
Re: wing table
Postby lrrowe » Mon Apr 25, 2016 6:40 pm
My plan for a light weight table top is to build one with 3/4" foam sandwiched between two sheets of 1/4" lauan with a rim of 3/4" boards around the sides. Similar concept to what TD builders do for their walls.
Bob
lrrowe
Images: 439
Re: wing table
Postby Brushy_Bill » Mon Apr 25, 2016 8:30 pm
lrrowe wrote:My plan for a light weight table top is to build one with 3/4" foam sandwiched between two sheets of 1/4" lauan with a rim of 3/4" boards around the sides. Similar concept to what TD builders do for their walls.
Thank you, sounds like a great plan.
An additional block where the adjustable leg
mounts and it is good to go.
Beats one from solid or 3/4 ply.
Can still be finished out great.
Brushy_Bill
Re: wing table
Postby lrrowe » Mon Apr 25, 2016 8:51 pm
Great...and be sure to post photos of your work. I may order my rails this week, so just maybe I will start one soon.
Bob
lrrowe
Images: 439
Return to Camping Secrets
Users browsing this forum: Dean and Lin P and 2 guests
