les45 wrote:You still have to drill the holes for the bolt heads for the floor to fit flush on the side rails. The shims only go over the cross pieces.
,snip,
les45 wrote:OK, here is what I did. Cut a pencil down to about 2" long and sharpen one end. Clamp your floor in place and use the pencil to mark the holes. Then flip the floor over and drill the holes. Use a drill bit slightly larger than the bolts to give yourself some wiggle room.
