Trailer design, help needed
Re: Trailer design, help needed
Postby Onajourney » Thu Dec 09, 2021 10:34 am
I just finished my off road frame. My first suggestion would be make it at least 9'. That extra 1' makes a huge difference in the galley. Second, I did not get all worked up about the tongue angles. I just laid one on the frame, adjusted it where it looked right, made at least 3 connection points, and marked it. Then cut two. Worked great.
I put 35' tires on so is just a bit heavy at 570 lbs with 25" clearance. That will settle after the build. Image
Onajourney
Images: 181
Postby twisted lines » Thu Dec 09, 2021 12:29 pm
KCStudly wrote:Nothing against Tony's design, as it uses the center tongue member to attach a straight tongue coupler; just saying if you plan to use the standard A-frame style coupler with just the two outer members, they are set at 50 degrees included (25/65 each side).
I Have Two trailers using a standard off the local shelf 50 deg coupler style,
I have seen these used on overloaded dump trailers :shock:
I am also planning a trailer rolled 20 deg R instead of angled sides and top :thinking: Foamie & Light
Racking up; And Rapin foam
twisted lines
Postby ptulli » Sun Dec 12, 2021 8:21 pm
Onajourney wrote:I just finished my off road frame. My first suggestion would be make it at least 9'. That extra 1' makes a huge difference in the galley. Second, I did not get all worked up about the tongue angles. I just laid one on the frame, adjusted it where it looked right, made at least 3 connection points, and marked it. Then cut two. Worked great.
Great design, I'm hoping to be a bit lighter but i doubt it lol. Looks a lot like what I am thinking of. What are you using for axels?
Not sure if I will be using the A-frame style as I plan on using the off road articulating hitch, but also may make part of it removable. Just thinking ahead.
Tow Rig: 2016 Wrangler 2d, planning overlanding/off-road camper (squaredrop/squareback)
ptulli
Postby Onajourney » Wed Dec 15, 2021 3:53 pm
PTulli- I can't exceed 2000lb gross weight being my TV is a Jeep JK. I was going to use 2000lb Flexrides but there was a 10 week lead. I got a pair of 2000 lb Rigid Hitch Torsion axels on Amazon cheap and quick. Nearly the same as the Flexrides. There a bit of a PITA to mount but they worked out.
Onajourney
Images: 181
Postby KCStudly » Wed Dec 15, 2021 4:09 pm
All 2 dr JK's or just 4 cyl?
V6 Unlimited (4 dr) is 3500 lbs. My old straight 6 TJ 2 dr was 3000 lbs.
Postby twisted lines » Wed Dec 15, 2021 6:13 pm
Onajourney wrote: Torsion axels on Amazon cheap and quick. Nearly the same as the Flexrides. There a bit of a PITA to mount but they worked out.
Found 1000 Lbs as well :thumbsup:
twisted lines
Postby saltydawg » Wed Dec 15, 2021 6:37 pm
One of the cheap brands from amazon used to be made by dexter. I built a frame for someone on the cheap and ordered the stub torsion axles from amazon, came labeled with dexter labels.
Scott
Lost in Maryland
saltydawg
Postby ptulli » Sun Dec 19, 2021 9:03 pm
Onajourney wrote:PTulli- I can't exceed 2000lb gross weight being my TV is a Jeep JK. I was going to use 2000lb Flexrides but there was a 10 week lead. I got a pair of 2000 lb Rigid Hitch Torsion axels on Amazon cheap and quick. Nearly the same as the Flexrides. There a bit of a PITA to mount but they worked out.
I am in a 2dr jk as well. I will definitely have to check those out, thanks!
ptulli
