Is it okay to use a trailer that has rails?
Re: Is it okay to use a trailer that has rails?
Postby friz » Sat Jul 23, 2022 1:27 pm
tony.latham wrote:
how is it you think you know what the OP actually has?
'Cause I've looked at a lot of those trailers from various manufacturers when I was building a utility trailer. (And no, I didn't use angle.)
This is where I draw the line... the ol' Pico Light concept:
https://www.tnttt.com/Design_Library/The%20Pico-Light.htm
:frightened:
On your side of the argument, I thought about mounting the spring pockets and tongue directly to the floor of my camper. Getting rid of the frame altogether. In my case, the frame hides all the stuff I mounted underneath. It also gives a place to mount the lights and my precious.....bottle opener.
Sent from my SM-S906U using Tapatalk
The "Sin Bin"
150133
friz
Postby saywhatthat » Sat Jul 23, 2022 4:51 pm
we use the light weight frame on are rentals 520 lbs trailers .it works be it for the rectangle shape of the tube that's why I recommend boxing it if he cuts it cuz angle iron can buckle very easy in two different planes. We have access to a rocket engineer . Fortunately this is his trailer . If things go to s*** it's his problem not ours so I just hope he contemplates and looks at pluses and minuses and he has no issues. https://web.archive.org/web/20160331004 ... ight-1.pdf
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Postby tony.latham » Sat Jul 23, 2022 8:54 pm
saywhatthat wrote:we use the light weight frame on are rentals 520 lbs trailers .it works be it for the rectangle shape of the tube that's why I recommend boxing it if he cuts it cuz angle iron can buckle very easy in two different planes. We have access to a rocket engineer . Fortunately this is his trailer . If things go to s*** it's his problem not ours so I just hope he contemplates and looks at pluses and minuses and he has no issues. https://web.archive.org/web/20160331004 ... ight-1.pdf
You use a Pico Light trailer???
