tougne length
tougne length
Postby scopeaddict » Thu Aug 17, 2006 9:20 pm
ive a little more cash, how long should i make my tounge?
im building a 5X9 frame,
demensions/thickness of the tounge-tube would be nice also,
single tounge, with braces,
not an a-frame tounge,
id search but i get all confused and dizzy, frustrated and P.O.ed,
sorry for my questions,
johnp
Deep Sky imaging and need a warm place to curl up,
Have 4-angry squirrels powering a Jeep YJ,
will travel, eventualy,,grin
scopeaddict
Re: tougne length
Postby Joanne » Thu Aug 17, 2006 9:23 pm
Hi John,
I may not be answering your question exactly, but the common wisdom is that you want your tongue long enough that the trailer won't hit your car during a sharp turn or while backing up. That said, approximately the distance between the tow ball and the outer corner of your bumper (plus maybe a little).
Does that make sense? Is that what you are asking?
Joanne
scopeaddict wrote:ive a little more cash, how long should i make my tounge?
johnp
New! My Camp Cooking Forum
Project Desert Dawg website
Universal Health Care
Joanne
Queen of Cast Iron
Postby Dale M. » Thu Aug 17, 2006 9:28 pm
ON my chassis I made tongue length a few inches longer than the distance of center of ball hitch to further most point of bumper on tow vehicle. That way I can full jack-knife my trailer/tow vehicle in a parking place and create a sheltered space using one side of trailer and one side to tow vehicular and it gives me a lot of maneuvering (turning) room. And will not put bumper into front wall of trailer.... My frame is 54x108 inches, tongue is single length of 3x3x.120 steel tubing that goes back to catch second cross member and is fully gusseted...
Dale
Dale M.
Images: 18
Postby scopeaddict » Thu Aug 17, 2006 9:37 pm
thank you,
now how far under the trailer should i go
my jeeps 5.5 wide, and id give another.5 or 1ft,
so a 4ft tounge, from front of frame to jeep,
+ (4.5 feet?) for under the trailer??
for a total of 8.5???
that sound right??
johnp
scopeaddict
Postby alaska teardrop » Thu Aug 17, 2006 9:52 pm
    John,
    The link that Miriam posted didn't seem to work. So, here is a direct link to Andrew's pages about tongue strength.
alaska teardrop
Postby Miriam C. » Thu Aug 17, 2006 10:20 pm
http://www.tnttt.com/viewtopic.php?t=8190&postdays=0&postorder=asc&start=0
Sorry, I fixed it in the other and posted it here too. Good discussion on this one.
Aunti M
Postby scopeaddict » Thu Aug 17, 2006 11:17 pm
O.K. so now im seriusly confused, and my heads spinning,
the aussies are too strict, and everybodys got an opinion,
i did learn im doing a "composite" tounge, so i got somewhere,
i just wish someone would give me some safe thicknesses, and lengths to
buy and weld up,
i was going to go with 2X2x1/8 on my angle composit pieces and 2X3X1/8
on the tounge,
so that being said,
can i go out to 4 foot and be safe,
and how far back into the frame should i go??
thanks, and remember im brain-damaged so sometimes i "need"
crayons,
not said for pity,--just a fact of my life,
sh** just doesnt click -in like it used to,
johnp
scopeaddict
Postby Nitetimes » Fri Aug 18, 2006 12:29 am
on the tounge,
so that being said,
That'll work fine for your steel. Makes a good sturdy tongue.
I like my first X-member at about 20-24" and attach to that, but can vary that number depending on the trailer design.
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby madjack » Fri Aug 18, 2006 12:49 am
...What Rich said...use 2x18 tube for the tongue and run it back to the first cross member back from the front of the frame and run the side angles back to the side of the frame to make a triangular corner...makes a very solid tongue for anything but the very heaviest of offroad use
Re: tougne length
Postby Joseph » Fri Aug 18, 2006 5:49 am
I wouldn't touch a straight line like that for a free weekend in Pismo Beach... :R
Joseph
Joseph
Teardrop Pirate
Postby bledsoe3 » Fri Aug 18, 2006 8:27 am
Scope, Here's how I did mine. 2" X 2" X 1/8" frame. 2" X 3" X 3/16" tongue with 2" X 2" X 1/8" angle for the bracing on the tongue. Overkill? Maybe, but I know it's strong enough.
Hope that answers your question.
bledsoe3
Images: 112
Postby scopeaddict » Fri Aug 18, 2006 8:37 pm
THANKS GUYS that helps alot,
now i can get some more steel,
and i know what im doin,,, ;)
scopeaddict
