BILLYL wrote:My question is - does the 1175 have only one bearing per hub? The pdf file indicates that. While the 1800 has 2 bearings per hub.
BILLYL wrote:Joseph-
Thanks for the clarification. After 1600 miles I guess it's time to clean up and repack the bearings................
Bill
Dale M. wrote: If you are of concerned that bearing may be bad, then replace "China" bearings with quality Timken or Fafner bearing...
