DHAZARD wrote:For a 6 ½ foot wide tear you will have to extend your mirrors to see around it…
And you'll have to build the wheels in/under the body, unless you use small wheels, as anything larger won't fit within the 8 foot wide limit of many states.
If you build the wheels in/under the body, you either can't use that part of the body for a bed, or you have to raise it above the wheel boxes.
Like life, design is just a compromise....
Andrew
