Painting steel frame
Postby Juneaudave » Wed Sep 27, 2006 10:38 pm
I cleaned up my welded steel frame, coated and wet sanded it a couple times with spray can Rust-oleum autobody primer and think it will be ready for final paint next weekend. I'm not set-up for HPLV or regular spray applications.
Any suggestions on paint brand, type and number of finish coats to get the most durable finish out of a spray can? I want as good a finish as I can afford, but in my salt/wet environment, durability of the finish is probably more important. Thanks...Juneaudave
Juneaudave
Images: 380
Postby Leon » Thu Sep 28, 2006 12:52 am
Since you have already primed with rustoleum, that would be a good choice. I've used it and it has held up well for me. There are other, tougher finishes such as POR15 that can be sprayed or brushed, it is like a rock when dry.
Leon
Images: 21
Postby asianflava » Thu Sep 28, 2006 2:14 am
I used Rust Bullet, similar to POR-15 but less work. Don't get it anywhere where you don't want it. I didn't find any good solvents to take it off.
asianflava
Postby Dale M. » Thu Sep 28, 2006 10:34 am
I used Rust-Oleum ( primer and finish) and did it with a brush! (2 coats) .... Not the prettiest but it is black and protected.... Actually brushing lets you get in nooks and crannies of welds and corners where spray may not saturate/penetrate...
I just put down large paper drop cloth and propped frame up on side (vertically ) so I could paint bottom area well and went at it...
Dale
Dale M.
Images: 18
Postby McTeardrops » Thu Sep 28, 2006 1:50 pm
I've been told, by PPG and other paint reps, that automotive paints are not compatible with rustolium products.
I used rustolium black "hammered" finish on the last trailer. It looks good for a while, touches up nice, but doesn't hold up well in wear areas like fenders and tongue. Their regular paints have held up better, but won't allow spot touch up.
Lenny
[email protected]
I've reached the stage, in life, where my foam has more memory than I do!
McTeardrops
