What axle?
What axle?
Postby mtnair » Tue Nov 28, 2006 1:07 pm
We've decided on a 5 x 10. I had purchased the Kuffle Creek 10' plans about a year ago. Those plans are for a 4 ft. wide trailer you can build. The Generic Benroy plans are for purchasing a trialer.
My husband is going to build the trailer. If I am going to order an axle for a 5 ft. wide tear what would I order?
mtnair
Postby asianflava » Tue Nov 28, 2006 3:42 pm
It will be around 73in. This is just an an approximation, because there are a couple things that are dependent on your particular situation. You have to find out how much back spacing (offset) your wheel/tire combination have. You also have to decide how much space you want between the tire and wall.
asianflava
Postby mikeschn » Tue Nov 28, 2006 5:20 pm
Your best bet is to get a torsion axle from Southwest Wheel. You tell them how wide the chassis is, and they custom build the axle for you.
Andrew has a good drawing of this... does anyone have the picture handy?
Images: 479
Postby Steve_Cox » Tue Nov 28, 2006 6:13 pm
mikeschn wrote:Your best bet is to get a torsion axle from Southwest Wheel. You tell them how wide the chassis is, and they custom build the axle for you.
Oh yeah!!
Steve_Cox
Images: 196
Postby angib » Tue Nov 28, 2006 7:01 pm
Overall widths
Measuring tyre backspace
Flexiride clearances
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby mikeschn » Tue Nov 28, 2006 7:13 pm
Yep, those are the ones I was thinking of. Thanks Andrew...
I wonder if Southwest Wheel can give us a hub face to hub face dimension that is slightly larger than the chassis width would suggest???
Images: 479
