Hi Folks
Hopefully I can answer a few queries as to why my frame is the way it is: -
As soon as possible I will post a pic to demonstrate how the chassis- frame is level with the tow hitch on my Land Rover. The height is 17.5" from the ground to the hitch.
The box section crossmember keeps it all in line. The idea [to me] is that the TD will travel along the road level behind the car.
I do need some extra ground clearance as the Land Rover is a 4x4- the TD will handle 'off-road' better.
Also I'm fitting an 8" 'footwell' so we can sit at a table inside and drink our tea if it's raining- it does sometimes in England
The axles are rated @ 500 kg [ 1100 lbs] pre-drilled with 6 mounting bolts. The half axle assy. is bolted to the pre-drilled plate [u buy them too ready made] that is welded to the X-member.
Without the Box section crossmember it is much more difficult to 'bolt' the half axles
accurately into position. Doing it this way felt like I was working with a 'typical' axle [almost like that of a car].
Also the X-member is sized to suit the clearance of the tyre / wheel / fender alignment so that the wheels run properly outside the body of the TD.
Luckily the axle assy. is so far back it will not interfere with the footwell.
Half axles are light - cheap[er] and easily obtained & fitted- [in my opinion]. I won't be riding in the trailer so anything more complicated is unecassary. I really don't want to pull a trailer over 1100 lbs.
I hope this makes sense?
If not I'll get Andrew to translate!
Cheers
jyb
