I have a 2007 Honda CR-V with the factory hitch (1500# gross, 150# tongue weight) and 4-pin trailer connector. Even though I am planning a TTT with a weight of about 1000-1200#, I would like to use electric trailer brakes.
I am thinking about use a 6-pin connector adapter from e-trailer that plugs into the 4-pin connector. http://www.etrailer.com/pc-A~30637.htm This would mean that I only would need to run a power leg from the battery and a "brake" leg from the brake controller.
What do y'all think - too many connectors? Should I wire the vehicle just for the 6-pin?
Thanks
