4x8 ----> 5x10 ?
Postby Toytaco2 » Sat Jan 23, 2010 6:52 pm
Ditto on the baby moons questions. I gotta know!!:thumbsup: :thumbsup: :thumbsup:
Mike
Toytaco2
Images: 365
Postby jmcarey » Sun Jan 24, 2010 9:07 pm
It appears that most builders use a sub-frame under the floor. You could build your sub-frame to over hang the trailer frame. I would recommend half lap joints on the sub-frame. Run your 10' members on the bottom, and the five foot members on the top (half lap). This should make a frame sturdy enough to stand the test of time.
jmcarey
Postby Rlowell » Tue Jan 26, 2010 12:52 am
The lap joint is a good idea. I will be using "pocket holes" on almost all my corner and cross member subfloor frame. My test joints seem to be real strong. :) Am just now starting my first build.
Rod in Orlando
Plan your work...work your plan...at least that's the plan. Oh, just do it anyway!
gallery/image_page.php?album_id=1425&image_id=76342
Rlowell
Images: 42
Any tips to stretch a harbor freight 4x8 HD
Postby NWBeerKat » Wed Mar 10, 2010 3:19 pm
I just bought a 4x8 HD but I need a 6x10 1/2 (still not set on length or width). I was thinking since the 4x8 is really 2 4x4's It would be easiest to weld the extra length in the middle and redrill the axle bracket holes. Anyone have a link to page fore balencing a trailer?
-Mike
NWBeerKat
Postby mikeschn » Sat Mar 20, 2010 7:46 am
Tommy2tone_1999 wrote:Hey Mike,
Kaspersky Internet Security flagged the web address you gave as:
The requested object is INFECTED with the following viruses: HEUR:Trojan.Script.Iframer
Hope this helps.
Tommy
I found the trojan and removed it. Should be good to go now!
Images: 471
Re:
Postby Andymanout » Wed Mar 02, 2016 5:42 pm
Steve Cox I totally stole this picture for my cabin car on an HF 4 x 8. Thank you for posting this. I will be inverting the hitch bracket and doing the extended tongue trick on mine! Thanks again for the picture!
Steve_Cox wrote:
DMcCam wrote:What about building a 4 x 10 on a 4 x 8 trailer? Can it be done without a lot of reworking?
Dave
Not too much rework on this one. 2 of the cross members used in the sides to extend them and the axle moved back. Had to drill a few holes. Actual frame length 117", 2X4 on each end during the build brought the length to 10 feet.
"Go into all the world and preach the gospel to every creature." I'm gonna do it in a teardrop.
Andymanout
