I've read many of the posts wherein the advantages and disadvantages of each, and preferences of some for one or the other , have been discussed yet I am still on the fence as to which to choose. I once had hydraulic surge powered drums on a boat trailer and corrosion from brackish water caused them to drag; that in turn caused them to overheat, fail the seal, lose the grease and fail the bearings. It didn't seem to have happened on one trip. One of the disadvantages of the drum configuration I subsequently realized was the inability to visually inspect the inboard seals for evidence of problems; I switched to hydraulic surge powered disks which worked fabulously with my 3000# load in the flat southeastern USA. Now I need to select brakes for my 1300# (loaded) teardrop and I have long assumed hydraulic disks. I called Kodiak to ask about their small disks and the technician expressed some concern that such a light trailer might not have the mass, given the choice of actuators (for much heavier loads), necessary to actuate the brakes well, short of a strenuous stop. With that introduction, have any of you had similar failures, or experience with hydraulic surge brakes on a light trailer? How reliable are electric powered drums on travel trailers? Conversely is their reputation one of high reliability? They certainly seem to be common so one would think them to be proven.The ability to adjust their gain on the fly is attractive. What do you know?
Thanks,
John
