by KCStudly » Thu Sep 12, 2013 9:03 am
Very common to weld stub axle shafts into the ends of a longer square "axle" tube. You will find that the middle of the square tube is hollow.
Yes, you can extend the middle (I did it with round tube axles on my car hauler, however, I did it by making a spud insert that slipped inside). Best to add some plug welds in the outer tube near the ends of the cut inner tube, as well as the welds around the ends of the outer tube.
Before you go down that road be sure that the axle is rated for the loads that you intend to put on it with that size camper (those little axles always make me a little nervous).
Also, you should move the springs with the stubs/hubs (i.e. make the main rails farther apart, do not increase the distance from the wheel hub to the spring mount). The spring perch is where the most leverage occurs from the reaction force at the tire and you do not want to exceed the mfg.'s limits on this spacing.
My Build:
The Poet Creek Express Hybrid Foamie
TnTTT ORIGINAL 200A LANTERN CLUB = "The 200A Gang"Green Lantern Corpsmen
