Weight distribution hitch
Postby brandon32689 » Wed Aug 20, 2014 9:47 am
Not sure if this is right place for this. But what weight distribution hitch do you guys use or recommend. I pull my 8.5x20 enclosed with a 1/2 ton gmc it really don't squat much but I'd feel safer with one and the sway system.
I'm looking at eaz lift 230 shipped everything includes
Equalizer 500 plus ball 25
brandon32689
Re: Weight distribution hitch
Postby bdosborn » Wed Aug 20, 2014 8:39 pm
Is it a tandem axle? You don't need one unless it is....
Images: 777
Postby brandon32689 » Wed Aug 20, 2014 11:23 pm
bdosborn wrote:Is it a tandem axle? You don't need one unless it is....
Yes it's a dual axle I went ahead and orderd the equalizer hitch
brandon32689
Postby highdesertranger » Thu Aug 21, 2014 8:46 pm
why don't you need a weight hitch unless it's tandem axle. double negative sorry. so you are saying if it's a single axle you don't need a weight hitch, never heard that one. highdesertranger
highdesertranger
Postby bdosborn » Fri Aug 22, 2014 8:32 am
Let me rephrase that, I think it's more important with a tandem axle than a single axle to use a weight distributing hitch. The tandem axle carries more of the weight on the front axle when the trailer is nose down and you can overload the tires if it's too much out of balance. The weight distributing hitch distributes the weight evenly across the two axles. Of course, the tow vehicle can be out of whack too if it's nose is too high; not enough weight on the front wheels to steer and the weight distributing hitch helps with that too. It's easier to move weight around inside a single axle than a tandem to hit the tongue weight you want, especially if you are in the building stages. So it's not that you don't ever need a weight distributing hitch with a single axle, it's that you can probably distribute the weight in the trailer so that you don't.
Images: 777
