Tire damage or no problem ?
Re: Tire damage or no problem ?
Postby rbishopp » Tue Aug 04, 2015 3:03 pm
It took three tries to get that last post to go. A problem on the server ?
Our build not build >>> viewtopic.php?f=50&t=63761
rbishopp
Images: 24
Postby Padilen » Tue Aug 04, 2015 7:11 pm
Well I keep deleting posts that I'm trying to edit. So I guess my comments are needed.
Padilen
Postby Dale M. » Wed Aug 05, 2015 8:33 am
IF you air up to MAX watch center of tire for excessive wear..... As other have said, tire pressure is load (weight) related....
And if it were me, I would add spacers to see if you can get tire further away from "body" but then you might have fender issue on outside....
Dale
Dale M.
Images: 18
Postby pchast » Wed Aug 05, 2015 10:06 pm
The 'old' test was to chalk across the tread. Roll the trailer back and forth on a flat surface.
Note where its rubbed off and adjust the air pressure accordingly.
:thinking:
pchast
Images: 96
Postby rbishopp » Thu Aug 06, 2015 6:15 am
I will watch the wear on the rubber. I've done the chalk test with my truck tires so I'm familiar with that and ill give that a go too. I haven't towed anything this small and light before. the last thing I towed with any regularity was a two axel stainless steel water tank. Weighed a oh a couple tons I guess. :lol: I never hesitated with that thing. This little TD is a whole different feeling for me. Heading out this morning for fours days at Lewey Lake. Maybe I'll see one of you there.
Thanks again.
rbishopp
Images: 24
