New Harbor Freight 62647 & 62671 Super Duty frames
Postby schaney » Sat Jan 16, 2016 3:25 pm
I have written a few guides on modifying the Harbor Freight 94564 4’x8’ Super Duty frames to “shrink” them for Explorer Box and some upgrade ideas. Can share links if anyone is interested. Recently that model has been replaced by a 62647 or 62671, so need to do some updates.
Has anyone purchased one of these new models yet? Trying to confirm a few things without purchasing one each myself.
The 62647 manual shows a tube axle and tongue end supports which bolt to the frame. Is this the way it comes?
The 62671 show a picture of a tongue end support welded to the frame, then the instructions show a tongue end support that bolts on. The instructions show a U-channel axle. Which way are the tongue end supports? Is it a U-Channel axle?
Thanks!
Scott
Camping the "Compact Way"
schaney
Images: 262
Re: New Harbor Frieght 62647 & 62671 Super Duty frames
Postby dogscats » Sat Jan 16, 2016 6:05 pm
Sorry I miss read the numbers wrong
TODAY IS THE OLDEST YOU'VE EVER BEEN,
YET AT THE SAME TIME, THE YOUNGEST YOU'LL EVER BE,,, SO MAKE THE BEST OF IT WHILE YOU CAN, AND ENJOY THIS DAY WHILE IT LASTS
dogscats
Images: 20
Postby schaney » Sat Jan 16, 2016 7:20 pm
dogscats wrote:There a u tube video that show that the axle is round
Sorry, thought my post was clear, already know all about the no longer available 94564. My questions are about the 62647 and 62671 frames
Scott
schaney
Images: 262
Re: New Harbor Freight 62647 & 62671 Super Duty frames
Postby dogscats » Sat Jan 16, 2016 8:03 pm
Sorry I will drive over and ask for you Monday .Any thing more There is two HF close .If they have them do you want me to take pictures
dogscats
Images: 20
Postby schaney » Sun Jan 17, 2016 10:26 am
Would be great, sure pictures of the tongue end supports and axles would be helpful. Tried checking them out at my local one last week. System showed the 62647 in stock, 20 minutes later they still couldn't find them.
Scott
schaney
Images: 262
Postby irgod32 » Sun Jan 17, 2016 11:14 am
I have used a HF trailer before, the only problem is, if you ever need to replace the baring's, they are hard to find. These axels use a metric baring and in California, surprisingly they are hard to find. I had no problem with the U shaped axel. My personal opinion is these tiny trailer frames don't need a lot of strength, they are not very heavy, a round axel would just ad more weight. But I have decided to go with axels with standard baring's because of the ease of finding replacements. I have used a HF 4' wide trailer and made it into a 5' wide TTT. I just added side extensions and built on top. 5 foot wide is the way to go, so much more room.
Tiny Trailer Builders of America
Build it and they will come
irgod32
Images: 49
Postby dogscats » Sun Jan 17, 2016 7:02 pm
The two stores here did not have them. The store in Stockton had one. They not let me open the box . let me peak in a small hole . The axle is round not c shaped. Told that the tongue end supports are the same. I could not see them. Any up dates on the Modular component? The last out fit did not work out. Wont have the parts I need tell June.
dogscats
Images: 20
Postby schaney » Mon Jan 18, 2016 10:13 am
irgod32 wrote:I have used a HF trailer before, the only problem is, if you ever need to replace the baring's, they are hard to find. These axels use a metric baring and in California, surprisingly they are hard to find. I had no problem with the U shaped axel. My personal opinion is these tiny trailers don't need a lot of strength, they are not very heavy, a round axel would just ad more weight. But I have decided to go with axels with standard baring's because of the ease of finding replacements. I have used a HF 4' wide trailer and made it into a 5' wide TTT. I just added side extensions and built on top. 5 foot wide is the way to go, so much more room.
Thanks for the info. Here is a link on Replacement hubs/bearings for Harbor Freight trailers for ones with the heavier duty round tube axle.
Scott
schaney
Images: 262
Postby schaney » Mon Jan 18, 2016 10:16 am
dogscats wrote:The two stores here did not have them. The store in Stockton had one. They not let me open the box . let me peak in a small hole . The axle is round not c shaped. Told that the tongue end supports are the same. I could not see them. Any up dates on the Modular component? The last out fit did not work out. Wont have the parts I need tell June.
Thanks, which model was it, the 62647 or 62671?
TrailTop parts are still in the prototype / concept phase
Scott
schaney
Images: 262
Postby daveesl77 » Mon Jan 18, 2016 10:30 am
I cannot speak to the bearing availability, but Tractor Supply has hubs, with bearings, that are perfect fits for the large HF trailer. Cost is $55
dave
daveesl77
Images: 273
Postby dogscats » Mon Jan 18, 2016 11:22 am
62671 Was the # on the first box. They come in two boxes
dogscats
Images: 20
Postby schaney » Mon Jan 18, 2016 7:16 pm
dogscats wrote:62671 Was the # on the first box. They come in two boxes
Thanks, one piece confirmed.
Scott
schaney
Images: 262
Postby schaney » Mon Jan 18, 2016 7:17 pm
daveesl77 wrote:I cannot speak to the bearing availability, but Tractor Supply has hubs, with bearings, that are perfect fits for the large HF trailer.
Interesting, the thread I posted also discusses swapping hubs
Scott
schaney
Images: 262
Postby Talia62 » Tue Jan 19, 2016 11:52 am
Go with Dexter bearings/hubs when you replace them. Common size, easily found. Explained here:
http://tventuring.com/trailerforum/thread-310.html
Talia62
Postby schaney » Thu Jan 21, 2016 8:17 pm
Talia62 wrote:Go with Dexter bearings/hubs when you replace them. Common size, easily found. Explained here:
Yes, that is the thread referenced above
Scott
schaney
Images: 262
