Tomterrific wrote:Bearing Buddies are made for boat trailers. The hub is warm from towing a boat on the highway, now the trailer hubs are backed into cold water, the Bearing Buddy is spring loaded so no water can be sucked in from negative pressure. I'm not saying Bearing Buddies aren't nice but they are not made for greasing bearings. A hub needs pulled and bearings greased to be sure rthey have grease. You may find that bearings aren't really greased when the hubs were originally assembled.
T
Jdw2717 wrote:I repack mine every season especially if we plan any long trips. I also carry a spare tire and one of the hub sets with bearings and seals that are pre-greased from Northern Tool. Remember that when something fails, it will usually fail at the worst possible time at the worst possible place. At least it seams that way some times. I feel that I would rather repack the bearings in the garage at a no pressure pace then be on the side of some narrow road having to do it quickly and in a dangerous place.
