Timbren axle-less suspension.
Postby ClydeB » Mon Nov 21, 2016 9:38 pm
Anyone here know of or used the timbren axle-less suspension?
http://timbren.com/axle-less/
Trying to keep the overall height of the trailer as low as possible, saw the 4" drop spindles along with the no axle......... :?
Clyde
ClydeB
Re: Timbren axle-less suspension.
Postby ajps72 » Tue Nov 22, 2016 9:11 am
Is it better than torsion axles? I will be a little worried about punctures on the rubber thingy.
ajps72
Postby KCStudly » Tue Nov 22, 2016 9:34 am
capntelescope used them on his CNC build. He also has a write up on changing the polyurethane (IIRC) snubbers to derate them for a better ride.
Postby KingAirNeal » Fri Nov 25, 2016 6:24 pm
Have it, love it so far.
KingAirNeal
Postby KingAirNeal » Fri Nov 25, 2016 6:25 pm
KingAirNeal
Postby kayakdlk » Sat Nov 26, 2016 9:10 pm
kayakdlk
Images: 392
Postby KingAirNeal » Sat Nov 26, 2016 10:26 pm
kayakdlk wrote:http://tnttt.com/viewtopic.php?f=35&t=57134
Dan
It was your write up that swayed me to go the Timbren route. Thanks!
KingAirNeal
Postby ClydeB » Sat Dec 03, 2016 2:01 am
Thanks for the info!!!
Will let you know what I go with.
ClydeB
Postby Shaggy » Mon Feb 06, 2017 4:22 pm
ajps72 wrote:Is it better than torsion axles? I will be a little worried about punctures on the rubber thingy.
On those ones, the "rubber thingy" is solid, not pneumatic. In theory, they can tear, but it's not likely. Here is a thread about replacing one of the springs, so you can get a better feel for it. viewtopic.php?f=35&t=65537
Shaggy
