Wheel size
Wheel size
Postby wilhansen » Tue Apr 11, 2017 8:56 am
Hey folks!
I'm nearing the end of a renovation project. 1967 Roadrunner by L&M manufacturing. We picked up the trailer from a guy, had been on his property for more than 20 years.
I've got to get new wheels for it (nope, I don't have the old ones... :( )
I've looked around and can't fine out what wheel size I need!
The tires that we're on it were LT235/75R15 - 5 lugs
Does that mean any 15" 5-lug wheel will work?
wilhansen
Re: Wheel size
Postby absolutsnwbrdr » Tue Apr 11, 2017 9:00 am
Yes you'll need 5-lug wheels, but you should confirm the lug pattern first. Probably 5 on 4.5.
https://www.pacifictrailers.com/pages/h ... lt-pattern
How do you have the tires, but not the wheels? :thinking:
Zach
absolutsnwbrdr
Images: 405
Re: Wheel size
Postby aggie79 » Wed Apr 12, 2017 8:36 am
P235 is a fairly wide tire. Are you sure this is what came on the trailer? Typically trailers from that era had 14" wheels with tires in the P185 - P215 range even though they weren't designated as such back then.)
For more on our Silver Beatle teardrop:
Images: 670
Re: Wheel size
Postby swoody126 » Wed Apr 12, 2017 4:59 pm
this site has a full sized bolt pattern template you can print off and confirm your needs
http://www.trailer-wheels.com/assets/im ... mplate.pdf
sw
swoody126
Re: Wheel size
Postby Andrew Herrick » Thu Apr 13, 2017 1:04 am
Shameless plug for etrailer.com. I love 'em. And you can chat with a customer service rep to help find a good set of tires.
There's probably not one "right" size of tires. What matters is the size of the hub, bolt pattern, and what sort of loading you expect.
A few of my builds:
SEE MORE AT: boondockcampers.com
Andrew Herrick
Images: 15
Re: Wheel size
Postby Redneck Packrat » Tue Jun 06, 2017 3:10 pm
If it's been sitting for 20 years, and had LT235's on it, I would betcha it's either 5x5 (Chevy's halfton standard size) or 5x5.5 (Ford's halfton standard size) that the trucks had used for decades. Probably had whatever made it common to its tow vehicle.
Dad always switched out hubs on all trailers for 5x5.5's because he always had F100's and 150's through the years. His cousin (Chevy guy) always switched out hubs to 5x5.
Either way, the wheels are available very-reasonably from Southwest Wheel.
Wheel with tire: https://www.southwestwheel.com/c-39-trailer-wheels-and-tires.aspx
Wheel-only link: https://www.southwestwheel.com/c-49-modular-trailer-wheels.aspx
Good luck with your project!
Bill
Texas Gulf coast, near Corpus
Working on this, started 5/2017: http://www.tnttt.com/viewtopic.php?t=68614
Some days you're the bug, some days you're the windshield :?
Redneck Packrat
