Repacking bearings
Re: Repacking bearings
Postby swoody126 » Tue Apr 25, 2017 5:37 pm
dancam here is a cross section pic of a typical inner hub grease seal
you can see how the rubber portion is tapered to provide the protection i was mentioning
sorry i couldn't post this pic earlier PHOTOBUCKET wasn't playing well with others
the blue shaded part is the metal component that holds the rubber in place
the small round part is a spring that holds the rubber against the spindle
note the tapered inner point which actually contacts the spindle whre it allows the older grease to escape
any time you do pull the hubs it is not wrong to take a bit of fresh grease and wipe the inner surface of the rubber which allows it to play more friendly
here is a blow up of a common hub assembly
the shapes can differ slightly butt the order of assembly is always the same
¿ clear as mud, now ?
sw
swoody126
