Which ring do I tap/press to ease the grease seal out?
-outer
-middle
-inner
Thanks,
John
swoody126 wrote:IMHO, trying to save a seal is futile UNLESS you are on the side of the road in an emergency situation
the $$($3-$5 depending on the capacity of the axle) of a seal isn't worth chancing a failure in the NEAR future
i always replace seals EVERY TIME i have to remove bearings for service
just sayin'
sw
swoody126 wrote:Mahal217, here is a chart of what you are dealing with
sw
KCStudly wrote:Preferably you would use an aluminum mandrel that just fits thru the clearance hole behind the outer bearing race ("cup") so that your taps are spread evenly around the exposed edge of the race and you drive it uniformly. Short of that a brass or aluminum punch gently tapping all around a little at a time. No steel punches, please.
Same thing going back in with the new race/cup. Us a mandrel. If an arbor press is available, so much the better! No hammering is best.
