stabilizer jack handle issue
Postby CalJanKoz » Sun Jul 30, 2017 9:51 am
So the trailer we got already has stabilizer jacks (yay!)
but...
once we have walls up we won't be able to use the handle to crank them.
Any suggestions or modifications?
CalJanKoz
Re: stabilizer jack handle issue
Postby QueticoBill » Sun Jul 30, 2017 10:52 am
I assume you we - I assume a lot of us - can't see the photo because of photobucket's change on 3rd party hosting"?
QB
QueticoBill
Images: 22
Postby dancam » Mon Jul 31, 2017 11:24 am
Yeah, youll need to use another image hosting site or else just upload it to this forum
dancam
Postby CalJanKoz » Wed Aug 02, 2017 1:36 pm
dancam wrote:Yeah, youll need to use another image hosting site or else just upload it to this forum
QueticoBill wrote:I assume you we - I assume a lot of us - can't see the photo because of photobucket's change on 3rd party hosting"?
Oops here's the picture:
and noted... forget me using photobucket
CalJanKoz
Postby QueticoBill » Wed Aug 02, 2017 3:05 pm
CalJan - some may be able to see it. I still can't. Now I wonder if people can see the photos I post.....
QB
QueticoBill
Images: 22
Postby dancam » Wed Aug 02, 2017 3:25 pm
QueticoBill wrote:CalJan - some may be able to see it. I still can't. Now I wonder if people can see the photos I post.....
I cant see it either...
dancam
Postby Padilen » Wed Aug 02, 2017 6:19 pm
I can. It's a motorcycle trailer. Those jack's are usually used on tongue. If you want to use a similar jack get the side crank model.
Padilen
Postby dancam » Wed Aug 02, 2017 7:35 pm
Can see it now. Its not meant for the application. Lots of other jacks that will work well. Cut that one off and weld a stabilizer jack on.
Or a side handle one like padilen said
dancam
Postby KCStudly » Tue Jan 09, 2018 7:19 am
I realize this is an older thread, but you could remove the handles, buy a couple of cheap 3/8 ratchet extensions (yard sale, China tool store, Goodwill, etc.), cut the female ends off of the socket extensions, and weld them onto the ends of the jack shafts. Then you could carry a ratchet and use that to cycle the jacks up and down.
If it were me, I would remove the jacks altogether and install the kind that fits under the frame (just because I think it would look better).
Images: 8119
Postby Dale M. » Tue Jan 09, 2018 10:18 am
Here is solution to photopoop problem is using browser...
viewtopic.php?p=1220940#p1220940
Dale
Dale M.
Images: 18
