Harbor Freight Swing-Back Jack mod for easy turning & moving
Postby Bob Hammond » Tue Sep 12, 2017 11:18 am
Hello,
The HF swing jack with a caster can be clumsy for turning and moving a trailer, especially on soft ground. So I replaced the 5" hard plastic wheel with two 10" pneumatic wheels from HF ($6 ea). The video and its caption pretty much tells the tale. The axle was drilled in three places for hairpin clips to keep the wheels in position- at the outer ends, and another inside the wheel bracket to keep the axle in place for single wheel use. The towbar unscrews from the TEE on the axle when it's not needed.
https://www.youtube.com/watch?v=qxcBmNNdGrk
Curator
Museum of Unfinished Projects
Bob Hammond
Re: Harbor Freight Swing-Back Jack mod for easy turning & mo
Postby Bob Hammond » Tue Sep 12, 2017 12:28 pm
Here's a pic between the wheels. You can see the TEE and the hairpin clip.
Sent from my SM-G920P using Tapatalk
Curator
Bob Hammond
Postby Bob Hammond » Tue Sep 12, 2017 12:29 pm
Between the wheels. You can see the TEE and the hairpin clip.
Curator
Bob Hammond
Postby greygoos » Tue Sep 12, 2017 9:55 pm
Nice idea. thanks
greygoos
