5x8 Chassis Tutorial/Guide/Howto?
Postby bg » Fri Feb 03, 2006 1:09 pm
In a few weeks I'm going to begin building a 5x8 frame for Julie (oklahomajewel). I've been thinking about turning this project into a How-To for the home-builder that needs a frame made to order. I'd basically cover everything but the actual welding using basic tools (Chopsaw and Angle Grinder).
Is there any interest for a guide like this? I'm up for writing it.
Bobby(, Kim & Wayne)
bg
Postby toypusher » Fri Feb 03, 2006 1:32 pm
bg,
I think that there would be plenty of interest from this crowd. Lots of us have built a teardrop, but not our own frame.
toypusher
Images: 324
Postby rampage » Fri Feb 03, 2006 1:39 pm
I think that would be a great idea. I wouldnt mind seeing one for electrical systems as well.
"If you can't be a good example, then you'll just have to be a horrible warning"
rampage
Images: 5
Postby madjack » Fri Feb 03, 2006 2:56 pm
Bg, that is a heck of a plan and a very generous offer...I sure the write up would be appreciated and popular with many here...it would also fit in well with this boards "mission statement" and other build info
Postby bg » Sat Feb 04, 2006 1:17 am
Guess this tells me what I need to know. Once I can scrounge up some help to run the camera one weekend. Guess this means I gotta get the garage cleaned up to have some room to work :shock:
bg
Postby larryl » Sat Feb 04, 2006 4:49 pm
BG:
very kind of you. One of the many things on my "to learn how to do" is weld.
Larryl
larryl
Images: 22
Postby mikeschn » Sat Feb 04, 2006 9:18 pm
BG,
A good (free) PDF like that would earn you a place on the menu... ;)
Images: 479
Postby bg » Sun Feb 05, 2006 12:20 am
This would be a free guide. Outside frame Dimensions are 58"x96". Perfect for the generic benroy. I've learned quite a few things when it comes to keeping something big square, and It'd only be fair to share the wealth
bg
Postby Juneaudave » Sun Feb 05, 2006 12:35 am
Be sure to include a section on grinding off crappy welds!!!
:x
Juneaudave
Images: 380
Postby bledsoe3 » Sun Feb 05, 2006 3:22 am
I'm just glad Julie is going to get started. I can't wait to see the Breadbox!
bledsoe3
Images: 112
Postby doug hodder » Sun Feb 05, 2006 7:14 pm
JuneauDave....that is the most important thing about welding...after you wield a grinder for hours on end...you'll make sure you get your welding technique down from the get go....just part of the learning curve...the guy I learned from said "you weld it, you grind it" I decided I needed to learn to weld better.... :cry: good for you Julie...going to get one going!!!: Doug
Postby bg » Sun Feb 05, 2006 8:58 pm
Ain't that the truth Doug...
I've been sitting here writing the basics out and what tools you need, Basically comes down to, Buy a good angle grinder, You'll be using it... Alot.
bg
Postby bg » Sun Feb 05, 2006 9:48 pm
Looks like I'll have something to show by the weekend. Will be picture-less, but usable/reviewable.
bg
Postby bg » Wed Feb 08, 2006 12:52 am
Few details/changes to take note of.
1. I will be using a dexter #8 torsion axle
2. Most likely 13" wheels
3. The axle will be adjustable from 36-30" from the rear of the trailer.
4. I will be using an A-frame tongue with an Atwood coupler
5. The frame will be tacked together, then welded solid.
6. The main frame is 2x2x1/4" Angle with 2 crossmembers, allowing plenty of room for a footwell or storage bin.
All of this while I still need to completly restart on my own trailer.
bg
Postby madjack » Wed Feb 08, 2006 1:09 am
...thanks for the update BG...I appreciate what you are doing and I am sure others as well...I know Julie is and we finally get to get her inna trailer ;)
p.s. don't forget to work on yours too...OK
